DXF IMPORT
What version VW are you using?
If you are trying to import a 2004 file, you can get that message.
You can also get an error 3 when importing a DXF file that is a bad file.
If you are on VW 9 or 10, and the file is ac 2002 or earlier, the file is probably bad and will need to be regenerated on the end of the AutoCad user.
