Vectorworks, Inc Employee SBarrettWalker Posted November 16, 2016 Vectorworks, Inc Employee Share Posted November 16, 2016 There are currently no new versions of the If node in the standard library - the simplest solution would be to use a modified delete node. I have attached a version of the node that allows you to do this. (I use it all the time.) Delete.vwx Quote Link to comment
Oachl Kini Posted November 16, 2016 Share Posted November 16, 2016 Thanks for the quick reply! I already changed it myself. Maybe it should also be changed in the standard library.. Quote Link to comment
