Biplab Posted August 19, 2015 Share Posted August 19, 2015 (edited) The “Marionette” subsystem will provide the Vectorworks user with the ability to algorithmically generate geometry and other Vectorworks objects, using a graphical flow chart like language making the system very accessible to architects and other non-programmers. The basic unit of the language is termed a “Tile” and represents either a type or function. Marionette exposes the power and flexibility of Vectorworks scripting to designers and architects who do not want to work in a traditional text based language. Functions or Procedures are represented by “Nodes”. Vectorworks 2016 ships with an extensive library of nodes which are all easily accessible from the new Marionette Tool. Nodes are connected with wires. Data travels through a “Script” or network as we often call it, from left to right. “Input” nodes expect some argument to be supplied on the Object Info Palette. When the network is complete, it can be executed from the context menu. Edited August 19, 2015 by Biplab Quote Link to comment
Ilay Posted September 21, 2015 Share Posted September 21, 2015 Thank you and dev.team Also i found new info about “Marionette” at vw developer wiki pages. if somebody missed it, check out links as tech.info: Marionette Basics The Marionette Node Parametric Object Quote Link to comment
