Dimensions...The Untouchables
EricB
I'm not following when you say you are rotating the dimensions lines.
Can you explain what you are trying to do?
When any set of objects are grouped, the objects are then treated as one object, a group. THis is why you can't select the dimensions in the group.
If you ungroup them and still cannot select them, make sure you have Class OPtions set to Show Snap Modify Others under the Organize menu. All dimenisons belong to a class called Dimensions. If this is not your active class and you have Class Options set to Active only, that is why you cant select them.
When the dims are grouped, the group belongs to the None Class. Again, why you can select them as a group and perhaps not when they are ungrouped as dimensions.
If this is not what fixes the problem, please further describe the problem you are having with as much detail as possible.
