Biscontin Posted December 10, 2014 Share Posted December 10, 2014 Vectorworks 2015 PS2: how do you end a chain-dimensions without double-clocking? Right-click or ESC don't work as previously. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted December 10, 2014 Vectorworks, Inc Employee Share Posted December 10, 2014 I have never seen right click finish a chain dimension, ESC should cancel it entirely. I have always used double-click or Enter. Testing now, this appears to be the same behavior in Vectorworks 2014. Quote Link to comment
Biscontin Posted December 10, 2014 Author Share Posted December 10, 2014 Double click or Enter will not end the chain-dimension... but it creates one last dimension and then ends it. My situation is: If the chain-dimension is still active and I don't have a new point to hit, and I want to end it... how do you do that? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted December 10, 2014 Vectorworks, Inc Employee Share Posted December 10, 2014 If you forget to doubleclick the last point, you can press Delete to step back one click and place the cursor in the desired location, then Enter or double click to complete. This works with most multi-click tools like Walls or Polygons as well. Quote Link to comment
Biscontin Posted December 10, 2014 Author Share Posted December 10, 2014 Ok thanks. This would help, but still it does not end it, it just go back. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted December 10, 2014 Vectorworks, Inc Employee Share Posted December 10, 2014 If you're hovering over the last-clicked point however, double clicking or pressing Enter should complete the dimension without adding a new point as well. But no if you have the cursor floating away from that point it will attempt to create another one upon hitting Enter or double clicking. Quote Link to comment
Biscontin Posted December 10, 2014 Author Share Posted December 10, 2014 OK, so I have to double-click on the last snap point to terminate the command... correct? Is there a command string to associate to ESC key in order to terminate the command? Quote Link to comment
