Section elevation marker tool
Guest Wes Gardner
Hi Niels,
To create a section, use the "Create Section Viewport" under the VIEW pull-down. You have the option to show the marker with the section on your sheet layer. To show the marker in plan view, go to your sections sheet and click on the viewport that contains your section, down at the bottom of the Object Info Palette, choose "Section Line Instances", then choose the Viewports" tab whereupon you'll be able to choose which plan(s) to show your markers on.
Wes
