An easier way to apply an aerial image to a DTM is needed. The workflow I would image is the user aligns a scaled aerial bitmap to the DTM, selects both and a VW command then applies the aerial to the DTM in the correct location and at the correct scale. If VW needs to create a texture to do so this should be automated so the user does not have to do anything more than select the bitmap and the DTM and run the command. Maybe there is a way to do this now and I do not know about it.
David Poiron
0 answers to this question
