I would like to have an option to lock a certain dimension value. This way we can use 'normal' dimensions as constraints, instead of having to do things double.
E.g.:
The idea being: if you move the wall (between the dimensions in the attached image) that the door will keep the same distance to the moved wall, because that dimension is constrained/locked.
This will save a lot of time, by either avoiding extra constraints and/or moving the wall first and then the door.
(Obviously a 'locked' dimension text can still be changed by double clicking and entering as we have it now, no need for unlocking first.)
VincentCuclair
E.g.:
Edited by Vincent CLink to comment
0 answers to this question
