buz Posted July 11, 2002 Share Posted July 11, 2002 Is it possible to change the default settings for PIO's. I find often three or more settings that I would leave alone if they were diffrent from the default setting. Would be a real time saver if these defaults could be manipulated. tfyh Buz Quote Link to comment
Matthew Giampapa Posted July 11, 2002 Share Posted July 11, 2002 Yes you can change the defaults permanently. To do so, go to the "Create Plug-in" command in the organize menu. Select the PIO you wish to edit and click the Parameters button. In here you can select each value the PIO knows about and by using the edit button, change the default value. Please note, that you may want to make a back up copy of any PIO you edit. Some PIOs that use popup lists can be damaged if you switch the order or change value names. (This is actually very few in the more recent versions. We have been trying to make them more edit friendly.) Matthew GiampapaNNA Technical Support Quote Link to comment
