CMS Posted June 24, 2002 Share Posted June 24, 2002 I am running VW 8.5.2 on G4/400 with OS 9.2.Have set undos to 100 but all files state 'No undo history'. Is there and obvious solution to this?Any help would be much appreciated. Quote Link to comment
Guest Posted June 24, 2002 Share Posted June 24, 2002 Each time you close a file, the undo history is reset. When you open a file and do nothing, you should have no undo history. Once you draw something you should be able to go and undo whatever you just created. We don't reccomend leaving the setting to 100 undos unless you think you are going to need to go back that far. We suggest about 20-25. Of course, if you need more, by all means leave it as high as you need to.When you have it set to a high number, it will store more informtion in the memory and you can, sometimes, get out of memory errors. Quote Link to comment
