Mattheng Posted September 7, 2011 Share Posted September 7, 2011 Ok, desperation call here have a massive file with a DTM in it that I need several sections of by tomorrow. Only snag is that I want the heights given at irregular horizontal spacings. Tried Roadways, polylines, stake objects you name it, either it didn't work or it just gave regularly spaced station points which just won't cut it. Have done normal sections instead but they are causing massive headaches with precision and getting accurate measurements in by hand. Attached is a simple file with a Nurbs roadway where I would like the section with Stations where I would like to see the heights but I cannot make it work. Any ideas? Matt Quote Link to comment
Mattheng Posted September 7, 2011 Author Share Posted September 7, 2011 Nil desperandum, the answer is do not use roads, nurbs, stake objects or polyLINES but use polyGONS. And just draw a line clicking on all points that you want shown and it works.... Oh and do not create a closed polygon or it still won't work... Matt Quote Link to comment
