urbangyal Posted August 12, 2011 Share Posted August 12, 2011 Hello all, newbie here :blush: sorry if im asking a stupid question here, but i normally use autocad and im trying to learn vectorworks fluently enough to draw a simple floor-plan of a house... i am a beginner to this program and i am wanting to know: -how i can make the walls with a fill/colour appear 3D -how do i add a shadow to the walls -how do i check what measurments the program is running in? (ft/m) and how can i change this? -how do i set the size of the template, eg to make it have a bigger area to draw a bigger plan? if sombody can sombody help me it would be much appreciated!! i want my floor plans to look exactly like this....: Floor Plan Quote Link to comment
Guest Posted August 13, 2011 Share Posted August 13, 2011 Looks like a concrete precast wall system with full storey height external panels or is it single storey height "Brick 'n Stick construction"? Either way this will influence the set up of your MODEL, layers, classes and (save as) templete. The shadows and colors are generated in rendered 3D MODEL Top view..I suggest you read the manual. Quote Link to comment
urbangyal Posted August 13, 2011 Author Share Posted August 13, 2011 oh crap im screwed (iv NO idea what u just said) lol, but thanks anyway... i have no idea how this image was ...i just know that I WANT MY WALLS TO LOOK LIKE THAT, once ive drawn my plan (which is easy enough). there is no way i can just insert a fill or sumthing to giv it that effect or any other command on vectorworks that can do it???? if u guys have any ideas would love to hear them!!! (plz bear in mind im a total newbie & dnt know alot of techy stuff yet Quote Link to comment
mar schrammeyer Posted August 13, 2011 Share Posted August 13, 2011 http://techboard.nemetschek.net/ubbthreads.php?ubb=showflat&Main=32082&Number=157803#Post157803 check this thread Quote Link to comment
Dieter @ DWorks Posted August 13, 2011 Share Posted August 13, 2011 Is this the thing you want? If you want the file, just contact me. It's not that hard. Just make your walls with two components, one light and one dark. Set them by class. That way, you will be able to change the colors later through viewports. For the shadow, you have to use the solution as mentioned above. Just use low walls and turn of some classes. Quote Link to comment
urbangyal Posted August 16, 2011 Author Share Posted August 16, 2011 yessssssssssssssssss thats exactly what i want i sent u a private msg with my email if u could help me would be fantastic! thankssssssss Quote Link to comment
Dieter @ DWorks Posted August 16, 2011 Share Posted August 16, 2011 (edited) I'll post the solution here so that others can learn and get ideas too. You can do it without or with Renderworks. Here is a short description on how you can do it. Just let us know when you do need more. I attach the file if you want to inspect it. Edited August 16, 2011 by DWorks Quote Link to comment
VincentCuclair Posted August 16, 2011 Share Posted August 16, 2011 Isn't it easier to do the plans in VWs and the colors and shadows in Photoshop? (It seems like a strange way of representing walls though? The shadows I can understand but shading the inside of the walls is rather strange.....me thinks..) Quote Link to comment
Dieter @ DWorks Posted August 16, 2011 Share Posted August 16, 2011 Isn't it easier to do the plans in VWs and the colors and shadows in Photoshop? (It seems like a strange way of representing walls though? The shadows I can understand but shading the inside of the walls is rather strange.....me thinks..) It all depends for what you need those plans. If you haven't got anything, and want presentation plans, but non other than that, I think it's faster done in VW once you have set up a base file for it. I really don't think you use those walls for implementation plans. If you have already plans, you can very easily convert them to this kind of plans through viewports and overrides etc... This way, when the plans change, your presentation plans will also be update. And with this thought in mind, I really think VW is much faster than photoshop, but you need a first setup to do it of course. Quote Link to comment
