Pete (STZ)
Wall - Floor Joining issues in Model
Argh...
Hoping someone can shed some light on this one... When viewing the same wall and different angles I see different things...
I have two walls in the same plane on two different storeys, with a slab in between.
When I view at an oblique angle the walls and slabs merge together and I see a nice smooth plane with no joins (see view 1)
When I rotate the view more towards an elevation - the joins appear (see view 2) When viewed in elevation all you see are the joins..
Any ideas?
Thanks
Pete
It's a bug. This bug exists through several versions of VW. It doesn't show up that much, but from time to time it does. Adjusting the angle a bit will solve your issue. You'll have to play with it for a while.
