Window Tool Display Problems
Hi all,
I wanted to see if anyone can explain the strange behavior I am seeing with the Window Tool.
When you open the attached file you'll see 2 identical windows in Top/Plan view. They are using classes to define the line wights of the Jambs, Glazing & Sill. The walls they are in are identical as well.
If you select one of the walls and delete all the components you will see that the window in that wall stops displaying properly.
I don't know why this is. The window settings have not changed.
If you change the wall back, remove the window and re-place it in the wall you find it displays correctly again.
Any thoughts?? Anyone??
