djb Posted October 27, 2010 Share Posted October 27, 2010 I'm attempting to learn worksheets and I am have difficulty with reporting areas of walls in worksheets. Apparently when "wallarea_gross" of wall is queried the number reported is the length x height x number of surfaces in wall type. Is this right and how do I get it to report the components of the wall and the correct area? CriteriaSurfaceArea reports a sum of every surface including the tops, sides and bottoms of the wall. Bug, wrong function or a waste of time? Quote Link to comment
Jeffrey W Ouellette Posted October 27, 2010 Share Posted October 27, 2010 Look in the VW2011 Help index under: Worksheets > functions of Scroll down the table and you will find that the components of any wall style can be queried by: =COMPONENTAREA =COMPONENTNAME =COMPONENTVOLUME Quote Link to comment
djb Posted October 28, 2010 Author Share Posted October 28, 2010 Jeff, Tried it and I get weird numbers, shows the wall thickness I think. Went back to version 2010 and had no problem, though no componentarea there. Also, how do I query componentarea for specific component, for example the exterior component? Quote Link to comment
Peter Eichel Posted October 28, 2010 Share Posted October 28, 2010 djb, look at the wall components in the wall edit popup. You'll see that each component has a number shown in the column on the left. Use that number within the formula "=COMPONENTAREA(2)" for example (not sure of the proper syntax). This will output the area for that wall component only and not the others. Quote Link to comment
djb Posted October 28, 2010 Author Share Posted October 28, 2010 Thanks Peter, that worked. I was using the syntax shown in the help files "(t=wall,1) and it was giving the name of the wall. Now if it would give proper areas for the components, then we'd have something. I have a wall with the siding extended down 12" ( to cover the first floor frame, version 2011) and the number reported is less than a wall that dos not have the extension. What's up with that? Maybe it's a bug. Quote Link to comment
