Yancka Posted April 14, 2010 Share Posted April 14, 2010 (edited) I'm looking for the answer, does it seem possible to create ferroconcrete slab object (would it be command, plug-in or smth else, doesn't matter)? The source would be 3D and 2D objects, the outcome would be an object with properties like these: 1. certain top elevation, 2. certain thickness 3. on sides where 2D lines were the edge is straight, 4. on edges where there were shaped 3D objects as determining elements, the shape is made as something like solid subtraction (in other words - concrete is filled until outer shape of object). As of armature, I don't think it's so big issue as body of concrete. See attached file for desired 3D object. Any thoughts, hints, ideas? Edited April 14, 2010 by Yancka Quote Link to comment
