lineweight Posted March 29, 2010 Share Posted March 29, 2010 Hello, I'm trying to create a custom stair. It's effectively a U stair. The first step is a landing, you turn 90 degrees go up about 5 steps to a second landing, turn another 90 degrees and go up to the second floor. Relatively straight forward. Now, my question is how to best go around this. Should I use a custom stair? I have it modeled as a custom at the moment, but it was inconvenient to do. between landings I had a fixed width and wanted VW2010 to figure out what the risers would be in a fixed width. In this instance, I had to do the math to figure this out. So, question one: Is there a way to set my dimensions and have VW figure out riser height/tread depth for me in a custom stair? Question 2: If I use the regular stair tool, is there a way to insert landings and/or customize first and last tread dimensions? Thanks! Quote Link to comment
