bburnet Posted October 31, 2001 Share Posted October 31, 2001 I recently downloaded the v9.5 beta, hoping it would fix some of the printing problems I've been having (spefically: missing text). When I try to print these drawings, all I get is: ERROR: undefinedresultOFFENDING COMMAND: stroke STACK: This occurs regardless of which printer I send the job to (HP 4050N, Xerox Phaser 790). Any thoughts? Thanks,Bryce BurnetIT Support SpecialistGeron Corporation230 Constitution DriveMenlo Park, CA 94025Ph: 650-566-7176Fax: 650-473-7750 Quote Link to comment
Matthew Giampapa Posted November 1, 2001 Share Posted November 1, 2001 Bryce, Are you using a Windows computer or a Macintosh to print? Also, what driver revision are you using? I would first try updating your printer drivers from the manufacturer. If this does not resolve the problem, send an email to bugsubmit@nemetschek.net with your system information (Computer, Printer, and Driver version) and attach a sample document where you see the problem. Matthew GiampapaTechnical Support quote: Originally posted by bburnet: I recently downloaded the v9.5 beta, hoping it would fix some of the printing problems I've been having (spefically: missing text). When I try to print these drawings, all I get is:ERROR: undefinedresultOFFENDING COMMAND: stroke STACK: This occurs regardless of which printer I send the job to (HP 4050N, Xerox Phaser 790). Any thoughts? Thanks,Bryce BurnetIT Support SpecialistGeron Corporation230 Constitution DriveMenlo Park, CA 94025Ph: 650-566-7176Fax: 650-473-7750 Quote Link to comment
