udi Posted October 30, 2001 Share Posted October 30, 2001 i have a gui problem, when i'm selecting object and try to change his class in the object info palette, the classes button is not active. on the same file in another copmputer it work completly ok. it's really disturbing pls help Quote Link to comment
Matthew Giampapa Posted October 30, 2001 Share Posted October 30, 2001 This sounds like your preferences may be corrupt in some way. To reset them to the factory defaults please see this page. VectorWorks 8.x Preference removal If you are using VectorWorks 9, the instructions are the same, but you would delete the "VectorWorks 9 Prefs" on the Mac, and on Windows the folder is called "Nemetschek" not "Graphsoft". Matthew GiampapaTechnical Support quote: Originally posted by udi: i have a gui problem, when i'm selecting object and try to change his class in the object info palette, the classes button is not active.on the same file in another copmputer it work completly ok.it's really disturbingpls help Quote Link to comment
