Greg_at_ils Posted February 26, 2010 Share Posted February 26, 2010 Just an FYI to anyone trying to use the help file to figure out drawing coordination as it relates to the title block, there is an error. In help file under: Vectorworks Fundamentals -Dimensioning and Annotating --Adding a Sheet Border ---Creating a Custom Title Block in Vectorworks It currently states: "Use an SN_ prefix to indicate that a field should gets its value from the Sheet Number of its sheet layer. If Use Automatic Drawing Coordination is enabled in document preferences (Design Series required), the SN_ prefix also means that when this title block field is updated, the Sheet Number of the sheet layer and of annotation objects on the layer are updated." It should state "_SN suffix" not "SN_prefix". Quote Link to comment
Guest Frank Brault Posted March 4, 2010 Share Posted March 4, 2010 Thanks Greg, for calling this to our attention. I have reported this and it will be addressed in the help documentation for our SP3 release. Quote Link to comment
