Ron Kenyeri Posted July 28, 2004 Share Posted July 28, 2004 Hello Support, Why is that when I make any type of extrusion that is not a simple rect or circle, I get the above error close to 50% of the time? I used simple, line and arcs to build a profile, "composed" the profile. Then extruded it. Did a render and its ok. Made a circle, extruded it, and tried to add the two solids and got the error above and my profile was unpicked. This is driving me nuts! Thanks, Ron p.s. VW 10.5.1, MacOSX 10.3.3 Quote Link to comment
Guest Posted July 28, 2004 Share Posted July 28, 2004 Can you include the entire message, please? Quote Link to comment
Ron Kenyeri Posted July 28, 2004 Author Share Posted July 28, 2004 The complete message is: "There were objects selected which are locked or are illegal in 3D solids. They have been deselected." As far as I can tell this is a generic message, I have gotten it when I had end points that did not match, when I forgot to "ungroup", and some time I have no idea as to why I get this error. I wish it would be a bit more specific at to what is the problem. Thanks, Ron Quote Link to comment
Vectorworks, Inc Employee Biplab Posted July 28, 2004 Vectorworks, Inc Employee Share Posted July 28, 2004 This is not a message that says that the operation failed. This is an alert message which says that there were some illegal objects (example: light object) in your selection e.g. if you did a select all before doing Add Solids - the system deselects the objects for which Add Solids is meaningless. What you should do is issue the Add Solids command again - and it should work. Quote Link to comment
Ron Kenyeri Posted July 30, 2004 Author Share Posted July 30, 2004 I often get this error when I am trying to add two solids together. And I am aware that I can't have "grouped" solids or loci, etc. It seems to happen the most when I am trying to add a extruded solid to a revolved solid. Some time it works, some time it does not. I just don't see a pattern. Thanks, Ron Quote Link to comment
