Ron Kenyeri
Content Count
55 -
Community Reputation
0 NeutralAbout Ron Kenyeri
Rank
Apprentice
Personal Information
Occupation
Mechanical Engineer
Homepage
www.kenyericonsulting.com
Hobbies
robotics, machine design, programming
Location
Franklin Park, IL
Jeffrey, So could I read in a mechanical component in xxxx.stp using this VW Architect IFC? I would hate to spend the extra money, but I am loosing days have thing translated.... Ron Kenyeri
I can't import stp files with vw2008, does anyone know if I vw2010 can inport stp files? They are becoming the defaco standard in machine design, and I am finding it harder and harder to get people to translate to .sat or .iges while I wait for vw2010 does any one know a free app for the mac? I really need to get some work done..... Thanks in advance, Ron Kenyeri
1. I have a 400mhz PowerBook, 640meg Ram & 8meg graphics and is works fine for 2-D work. But its a problem for 3-D 2. VW-MECH has a great parts library. 3. Never had a problem with 2-D. 4. For the most part yes, but I haven't really used autocad for a few years. Hope it helps, Ron
DXF 2D parts files (compression fittings)
Ron Kenyeri replied to jimho2036's topic in Machine Design
Hello Jim, Try www.mcmaster.com its an industrial supplier that has cad files for most of their parts. I am a mac user as well, so I can tell you that most of their web buttons will not work when it comes to showing the image in your web browser, but the files do down load ok. In most cases they offer 2-D & 3-D files, I have used their compression fittings files (3-D iges solids) and they work well. Let me know how it goes, Ron -
2D Fillet, can't fillet a straight line to a arc
Ron Kenyeri replied to Ron Kenyeri's topic in General Discussion
Delmer, Yes, though of that too, got over 3/8" to spar on both sides. I can export the 2D file, and fillet in autocad 14 with no problems. Thanks, Ron -
Hello Forum, I need to fillet a .350R arc into a straight line with a 0.050R fillet. It works in autocad, it works in IDEAS-NX10, but VW generates a 0.026R .125 away from where it should be? This is a bug. I have a file that repeats every time. Who should I e-mail my file to? Thanks, Ron Kenyeri
Thanks Nicholas, Please do, I could us it. Thanks again, Ron
Hello Forum, Does VW ship with 3D hinges? Or does anyone know where I can download a file? Thanks, Ron
Hello Forum, Using the spur gear plug-in is it possible to set the pressure angle? And if not what is the pressure angle fixed at, when VW draws a spur gear (is it 14.5?)? Thanks, Ron
I wanted to use the "circle by three points", the last option in the circle command. And enter three tangent points to define the circle. (I can do this in autocad 14....) But the smart snap command never displays any choice but "object". Tom I am running VW Mechanical, I will try you suggestion. Thanks, Ron
Tom, In most of my catalogs, spur gears come in 14.5?, 20?, and 25? pressure angles. With 20? being the most common (all of the gears we sell are now 20?). FYI, 14.5? is going to be phased out for new machine designs in the next 5 years (or atleast that is what SME tells me;) ). So to make my story short, yes, it would be very usefull. Thanks, Ron
Hello Everyone, Has anyone been able to get the constrain by tangent to work in 11.5? I need to place a circle using the 3 point tangent option by I never get the tangent constrain option on the screen, its always "object". Even when the only option active on my constrains panel is "constain by tanget" Any insight would be appreciated! Ron
I would love a desktop. But I spend 90% of my time at on location so I am chained, if you will, to a laptop. I was planning to wait for a dual core G4 or a G5, but I don't know if I can waite that long. Ron
Andrew, I do machine/tool design. On average I have 10 plates 20 or so screws and lots of openings in my 3-D models. What would consider a solid midranged G4 cpu? 800 mhz or more? Thanks, Ron
Just upgraded to 11.0.1, and it is worth the money. BUT, the dashed hidden line, while much better that before, is really slow, compared to 10.5. Given that I have a TiPB 400mhz... I realize that I need to upgrade my hardware. What I am asking is how critical is the graphics card to VW, or would my money be better spent on more memory? Thanks, Ron Kenyeri
