gray layer help needed
domer1322
I have a viewport with 3 layers and one is set to be gray in the viewport layer control. The gray layer shows wall with components. When I print the sheet, the components of the walls (brick hatching) shows up as gray, but the outside wall lines show up black. I've adjusted the gray layer percentage on the print dialog box with no affect. What am I missing ?
Is this a bug or operator error ?
using VW Arch 2009 Windows XP
