tedD Posted September 18, 2009 Share Posted September 18, 2009 Hi, My VW10 and VW11 don't have basic UI. When I CTRL+Z for example the application doesn't undo, and I have to go to the menu->Edit->Undo. What is happening here ? Thanks in advance ! Quote Link to comment
Ray Libby Posted September 18, 2009 Share Posted September 18, 2009 Welcome to the forum. Please create a signature with your version of Vectorworks and computer specs including OS. Click on the My Stuff link, Edit Profile. In this case your OS is need to answer. Quote Link to comment
brudgers Posted September 18, 2009 Share Posted September 18, 2009 (edited) Did you try quitting Vectorworks and restarting? Did you try rebooting? Are you using a compatible version of quicktime? Does control-Z work in other applications? Have you tried a different keyboard? Have you tried unistalling each 10 and 11 and reinstalling and testing them one at a time? Edited September 18, 2009 by brudgers Quote Link to comment
tedD Posted September 18, 2009 Author Share Posted September 18, 2009 Hey guys, thanks for the replies! I am using a P3 with 2GB with windows XP Professional... I tried switching to another keyboard. no go (both are ps2, non usb keyboard was tested yet though) I tried resetting the computer, and as well only restarting the app. no go I tried copying text from another app, into VW and it pastes great. All other CTRL combinations are just not happening (ctrl+z ctrl+a ctrl+x ctrl+c ctrl+v ... etc) quicktime was never installed on this system. But used to work here. [limited, can't install anything here] Seems that this issue is coming from VW because CTRL works perfectly on any other app on this computer. Is there a keyboard configuration for this app ? Quote Link to comment
starling75 Posted September 19, 2009 Share Posted September 19, 2009 Hey guys, thanks for the replies! I am using a P3 with 2GB with windows XP Professional... I tried switching to another keyboard. no go (both are ps2, non usb keyboard was tested yet though) I tried resetting the computer, and as well only restarting the app. no go I tried copying text from another app, into VW and it pastes great. All other CTRL combinations are just not happening (ctrl+z ctrl+a ctrl+x ctrl+c ctrl+v ... etc) quicktime was never installed on this system. But used to work here. [limited, can't install anything here] Seems that this issue is coming from VW because CTRL works perfectly on any other app on this computer. Is there a keyboard configuration for this app ? You need to install approprite version of Quicktime. Keybord / shortcuts customization is availible in workspace editor - here (No sure if it has the same location in older versions of VW.) Quote Link to comment
tedD Posted September 19, 2009 Author Share Posted September 19, 2009 We tried to monitor windows messages going out to VectorWorks, and we could see that WM_KEYDOWN and WM_KEYUP were sent to the app. We also tried to replace the keyboard to a USB one but still no go. The Workspace settings were good for a few shortcut keys, but we could not find a place there where you could substitute a ctrl+Z to something else... Seems like something internal to VW. Any ideas ? Quote Link to comment
Ray Libby Posted September 19, 2009 Share Posted September 19, 2009 Try changing workspaces. Try creating a new user in XP. You could try reinstalling Vectorworks. How old is your install of XP? A reinstall of XP may be necessary. Please put your specs in a signature so we don't have to hunt it down. Quote Link to comment
