Ronald Prochot
view layers multiple layers in MiniCAD 703
When I view my house model in Model view, on the model layer, all layers apear as tehy should - ie in perfect alignment one above the other. However this alignment breaks down when I try to view layers multiple layers simultaneously eg - isometric view of exterior walls and roof framing. Both layers appear to be occupying the same space, ie trusses and beams sit at floor joist height. Is there a way I can align the layers so I can work on them while being able to see the relative position of each layers in relation to the other layers, or do I have to create a seperate linked model layer: roof and walls, floor joists and foundations, etc.? (eg I wish to draw a saddle/beam connection which requires me to be able to view roof beams and walls in plan and in section, and in proper alignment.) Idealy I want to be able to work on the active layer while being able to view the other layers in proper alignment to other components of the model. Any suggestions would be appreciated. The simpler the better.
THANKS!
quote:
Sounds like you haven't set the Z coordinates for each of your layers. I believe in version 7 you can set the Z coordinate globally in the Layer Setup dialog box. But, if I'm not mistaken, after you have created objects you can't use this to change Z coordinates globally. You may have to move everything (using <Ctrl+Alt+M> )
