Import DWG problem 64 bit on PC
Hi, Has any one had a prolem importing a DWG drawing into Vectorworks 12.5.3 in a 64 bit PC? The files work fine when I do it on a smaller 32 bit machine, but I when I do it on the 64 bit OS it sayes that I have insufficient memory. ie: 42976 k additional memory must be available to import this file. this is just an estimate...larger.
This is the first import I have tried using the 64 bit system, everything else works fine. Is this a compatibility problem with 64 bit and vs 12.5.3?
Thank you,
Tom
Intel dual core 3.16ghz
4gb RAM XP pro x64 PC sp2
Vectorworks Fundamental 12.5.3 (80532)
Thanks I found I should have posted this on DWG forum and not here. I did see where this problem was known for 12.5.3
Thanks again
Tom
Intel Dual Core 3.16ghz
