patric Posted January 30, 2009 Share Posted January 30, 2009 Hello again, another problem: I have written a little menu layout. The problem is: when I select an item of the pull-down menu the window of the menu closes. I want it to stay until I press 'OK' or 'cancel'. And in addition to that, the selected Choice is not stored when I press OK... Does anybody know a solution? Quote Link to comment
Miguel Barrera Posted January 30, 2009 Share Posted January 30, 2009 Make sure your items start at number 4. 1-3 are reserved for the OK, Cancel, and Help items. I do not know what you mean by the "choice is not stored". Can you elaborate on this? Quote Link to comment
patric Posted February 2, 2009 Author Share Posted February 2, 2009 Thanks for the help, it might be, that the '1-3'-thing will solve all of the problems. 'choice is not stored' should have expressed that when I pressed the OK Button and did not select any item in the pull-down menu, the default string of the pull-down menu couldn't be accessed. It just gave the default integer. Quote Link to comment
patric Posted February 3, 2009 Author Share Posted February 3, 2009 every problem is solved! Thanks for the help! Quote Link to comment
