Drawing Label
Mar,
Open the drawing and select the Drawing Label tool. Before placing any Drawing labels, select the Preferences button in the Mode Bar. This should open the settings dialog for the Drawing Label object. Delete any text in the "Dwg Title:" field. Select OK button.
Now when you place a Drawing Label inside a Viewport, it should default to the VP name.
If this doesn't work, a bug will need to be submitted.
Edited by Jeffrey W Ouellette
