Sybil Posted September 16, 2008 Share Posted September 16, 2008 How can I make the wall go back to it's regular height after already closing the document and saving the changes? I need to make roof changes and put in an attic, instead of having loft ceilings and letting the interior walls go all the way up to the gable peak. Thanks, Sybil Quote Link to comment
C W Posted September 16, 2008 Share Posted September 16, 2008 (edited) There's not a command for this but one option is to create a flat plane at the desired height and then fit walls to that item. But it may be worth it to you to use this script - See previous post below: Post Edited September 16, 2008 by C W Quote Link to comment
