mmyoung Posted August 21, 2008 Share Posted August 21, 2008 I always wanted to mix rendering styles, rendering one part in wireframe, for instance, and the rest in a solid style. Now it's happening unbidden and I can't seem to stop it. Does anyone know if this an effect I ought to be able to control, or has something gone haywire? thanks VW 2008 SP3 b88670 Intel iMac 2GB; 10.5.4 Quote Link to comment
Ray Libby Posted August 21, 2008 Share Posted August 21, 2008 If it's a viewport, in the OIP you have Background Render and Foreground Render. Maybe you accidentally set one of them to render instead of None. Quote Link to comment
CS1 Posted August 21, 2008 Share Posted August 21, 2008 I had this occur the other day, I had a viewport showing a custom view, when I rendered as openGL half of some objects appeared as hiddenline, in final quality renderworks appeared normal, would be a cool effect if I could have controlled and altered it. After I closed and restarted my machine the occurance stopped, only had it pop up a couple of times since then , have no idea why. Quote Link to comment
