ErichR Posted July 22, 2008 Share Posted July 22, 2008 I've researched this problem here with little luck. A file is referenced to a design layer. A viewport of it is created to a sheet layer. Annotations are added. Files are closed. Upon reopening, the referenced file is significantly offset in location from where it was originally positioned. In the sheet layer, the referenced image is, of course not there, but the annotations are. I've tried locking the design layer, but this doesn't help. Any ideas? Quote Link to comment
Marietta Posted July 22, 2008 Share Posted July 22, 2008 Check to see if the scale is the same on the referenced layers. One other thought is to make sure you don't accidentally change the insertion point or 0,0. Quote Link to comment
