sketcher Posted May 5, 2008 Share Posted May 5, 2008 for some reason when i use the shift key to lock a line to horiz. vert., etc.... it locks it in at .003 degrees and the smart cursor says"Alt". im sure its just a matter of deselecting a constraint button, but which one? Quote Link to comment
maarten. Posted May 5, 2008 Share Posted May 5, 2008 Go to your VW preferences and set the Alternative angle to 0? (or an other angle that you find interesting to use). When using the shift button, VW will lock that angle, allong with the 30?, 45? and 90? angles. Quote Link to comment
sketcher Posted May 5, 2008 Author Share Posted May 5, 2008 NICE!!! i knew it was something simple! thank you for curing that little irritation maarten. Quote Link to comment
