Bart Rammeloo Posted October 1, 2003 Share Posted October 1, 2003 Hi all, There's a puzzling difference between CV selection for splines and CV selection for surfaces. For surfaces, you can easily select multiple CV's - just drag a marquee and use the SHIFT key to add CV's to the selection. But this doesn't work with curves. You can only select one CV or the complete curve. The obvious question is: why is there a difference? In my mind, it would make perfect sense to be able to select more than one CV from a curve. Anyone? Thanks in advance, BaRa P.S.: Biplab, yesterday I showed 3DPowerpack to a former PowerAnimator and Maya user. He was quite impressed. Especially the way solids behave was a hit! No better proof for the quality of what you have been doing Quote Link to comment
Vectorworks, Inc Employee Biplab Posted October 1, 2003 Vectorworks, Inc Employee Share Posted October 1, 2003 There are some technical issues to do this for the curves - nevertheless - this is very much in our list. The technical issue is the fact that a NURBS curve can have several pieces (some linear, some curvy with sharp corners between them). So when you select a bunch of vertices - you are actually reshaping several pieces together which makes the problem a little complicated. Quote Link to comment
Bart Rammeloo Posted October 2, 2003 Author Share Posted October 2, 2003 Thanks Biplab - glad to know you're "on top of it". If I understood it correctly, it's difficult to select "discontinuous" CV's (the ones that, when you would decompose a curve, would make it split)? Cheers, BaRa Quote Link to comment
Vectorworks, Inc Employee Biplab Posted October 3, 2003 Vectorworks, Inc Employee Share Posted October 3, 2003 Yes, if there are discontinuous pieces. Quote Link to comment
