Guest Posted March 8, 2008 Share Posted March 8, 2008 Hi Why is it that with 2008 the snap points an smart cues just dissapear ? file added to prove the point. Tx Quote Link to comment
Ray Libby Posted March 8, 2008 Share Posted March 8, 2008 Both snap points and smart cues work for me on your file. Try updating to SP2. Have you shut VW down and launch it again? Quote Link to comment
Guest Posted March 8, 2008 Share Posted March 8, 2008 Try all objects - some does en some does not - especially if I use spli tools and where I change the extrude properties - do a few changes too. Quote Link to comment
Ray Libby Posted March 8, 2008 Share Posted March 8, 2008 Ok, just tried every snap I could see and all works. Try putting an arrow to the spot and reposting. Quote Link to comment
Guest Posted March 9, 2008 Share Posted March 9, 2008 Try this one from Left View - on Front View it snap to a degree if you hang onto it. The snap is just not true "snappy" in Front View. I get this as a constant on objects which is split or heve holes in - and if yo adjust the extrudes then it is most of the times 0.1 - 0.2 of the seted length or thickness etc. Quote Link to comment
MullinRJ Posted March 9, 2008 Share Posted March 9, 2008 I believe it is because your object (solid section) is rotated -7.6? in the Y-axis to show the cross section orthogonally in a side view. Snapping works best when your view is orthogonal to the object. You are orthogonal to an arbitrary face of your object, but VW still sees it as rotated -7.6?. I think you found a limitation of the software, but not a true bug. Raymond Quote Link to comment
Guest Posted March 9, 2008 Share Posted March 9, 2008 TX Same happens on a solid in a fairly large file where you do a lot of splitting and fitting holes in a solid in VW 2008 - not in VW 12.5. That is only an extraction of 1 x part of a small file of 11 MB. If that one is like that, just think how many other members does the same and not at an angle setting even. - Driving me nuts as I use only 3D in 99% of all dwg's. Best of all is that the bug is admitted by TECH support and that the engineers is working on it from November 2007 but no word till now. The problem is that excluding the nuts driving factor is the total unreliabilty an incorrectness of VW 2008. Just thought there maybe something else that someone may pick up. Quote Link to comment
Guest Posted March 9, 2008 Share Posted March 9, 2008 Here is a typical occurence that is an integral problem of VW 2008 3D capabilities. This comes out of a file - it is a 50 x 50 x 5 Angle - note horisontal it is still 5 mm but the vertical is 4.98 mm. It happens after duplicate mode was used and the extrude length was changed. It just means if you work with VW the you cannot edit anything as it is completely untrustworthy as it sometimes gets to this point and other times it does not. Waste time in doiing everything over and over again. Quote Link to comment
MullinRJ Posted March 10, 2008 Share Posted March 10, 2008 Hi Conrad, ???The Poly inside the Extrude matches the 5.00mm and 4.98mm measurements you noted. Could you submit a file with two objects, one Angle before and another Angle after your Extrude Operation? I'd like to try it and see it change. Please specify how you are duplicating it, modifying the Extr length, and what view(s) you are in. ???I tried duplicating it with an Option-Click, Cmd-D, Mirror Tool, and Menu Duplicate; then changed the Extr length with the OIP and with Reshaper 13. I even changed the Extr length in ISO views. No problems here. Either the object was off to begin with, or you are doing something I didn't guess. Thanks, Raymond VW 2008 (SP2) R1 (build 82613) D/RW MACmini, OSX 10.4.11. 2GB RAM Quote Link to comment
Guest Posted March 10, 2008 Share Posted March 10, 2008 Was just getting it for the upteenth time - first time I get it so as "a constant" - This one is typical and I Intended to post it - You can see for yourself. Quote Link to comment
Guest Posted March 10, 2008 Share Posted March 10, 2008 Is there a change that VW will give me my money back ? Will gladly do that exchange. I got a half baked program with a problem which is from Nov 2007 at the "engineers" and are still sitting with it. My money was not teared, screwed or half paid btw ! Quote Link to comment
MullinRJ Posted March 10, 2008 Share Posted March 10, 2008 Again, I was not able to reproduce your results, but I do see what you are talking about. Can you outline in more detail how you create the broken shape? More detail is better. Out of curiosity, why do you section your solids with NURBS surfaces? I have no idea if it is causing your problem, but I used a 45? Line and extruded it to a plane to make the cut. Try cutting your Angle with an Extruded Line and see if you get the same results. Raymond Quote Link to comment
Guest Posted March 10, 2008 Share Posted March 10, 2008 I use only the split tool - it is fast but I always get those issue where it is not at 100% perducalar in the cut itself. Quote Link to comment
MullinRJ Posted March 10, 2008 Share Posted March 10, 2008 OK, I'll try that. back later..... Quote Link to comment
