help on "filleting" nurbs curves
Hi all,
I'm tracing the frame of a chair right now, but I've got problems with connecting the different straight parts AND applying a fillet.
Take a look at what I want to achieve at the following URL:
NURBS curve "fillet"
Right now I'm drawing the straight parts, and positioning arcs in between them, but that's a hell of a job. Is there any other way - some kind of filleting of NURBS curves? Something similar to Studio Tools' Blend curve?
Thanks Biblap, I was aware of that, but as you said: no radius. I can solve it with adding extra CV's, but I need to be able to position them on the correct distance from the corner CV. Right now I can only add the by hand, or by using cooridnates. Is there some kind of hidden trick to insert CV's using a distance from another CV?
Cheers,
BaRa
