Richard T Posted October 3, 2007 Share Posted October 3, 2007 I am trying to set up revision text in my titleblock so it is all aligned at the bottom, and expands upwards with each new revision. It seems to be all set up correctly in my titleblock symbol, but when I actually create revisions in the Drawing Border, they get out of alignment. The two attached images show the difference. I am trying to get each revision to sit in the same place relative to the horizontal lines going up the page, which are spaced 7.5mm apart. So I have set my revision text to Bottom for its vertical alignment, and with a spacing of 7.5mm which is immediately converted to 21pt. But as you can see, even the first line isn't aligned properly. The two leftmost text items are 8pt, and the right text item is 10pt. Help please! Quote Link to comment
