mar schrammeyer Posted September 4, 2007 Share Posted September 4, 2007 1.7168626677606e17mm must be the outer extend of my screen, its the the length of a wall after i tried to but it with an other wall, i have send a similar file to bugsubmit, anyone else came across this problem? and how did you solve it? Quote Link to comment
Dieter @ DWorks Posted September 4, 2007 Share Posted September 4, 2007 Did you try to make a T join with 3 walls? Because in VW 11, there was a bug when 3 walls of different thickness joined each other, one of them has a volume that wass infinite tiny, like your lenght. Quote Link to comment
Guest Posted September 4, 2007 Share Posted September 4, 2007 Mar, If you have the file before this change, send the file along with a note of which walls you are attempting to join and the join settings being used to both tech@nemetschek.net AND bugsubmit@nemetschek.net Quote Link to comment
mar schrammeyer Posted September 4, 2007 Author Share Posted September 4, 2007 Thanks Katie I send a downsized file as requested, and no DWorks like i said it is a straight butt joint I think it has more to do with the location on the drawing because i have the same butt joint about 8m away Quote Link to comment
