Edit Class Crash/Hang
I am finding that VW crashes/hangs when I try to edit the attributes of an existing class. In one particular case, I am editing the class by checking the use attributes at creation box, and changing the line color.
Is this a known bug?
I do have multiple plug-in objects, in particular arched openings in walls and complex windows with segmented arch tops.
Could it be that the program is hanging on the recomputation of all those objects? Or is there possibly some type of file corruption?
Thanks......Jack Fulmer
Jack, Most likely the program is trying to recalculate everything after you have made the change. I would say give it a few minutes then if the program is still not doing anything, try to copy the document layer by layer in to a new file.
