patrickb Posted August 10, 2007 Share Posted August 10, 2007 I can only snap on the active layer, despite having 'show / snap others switched on' - any clues? Quote Link to comment
jan15 Posted August 10, 2007 Share Posted August 10, 2007 Do the layers you can't snap have a different scale? 'Others' really only means others at the same scale. Quote Link to comment
Guest Posted August 10, 2007 Share Posted August 10, 2007 Ensure the views are set to the same view - which Align Layer views will do. Also ensure the layers are set to the same scale. If they are at different scales, you are not able to select/snap across the layers. You may also need to check class options. If that's set to Show Others, then you won't be able to select objects in other classes. Quote Link to comment
patrickb Posted August 10, 2007 Author Share Posted August 10, 2007 Thanks, but still no joy, so I set up a new drawing, copied across and it's working fine. Must have been a rogue drawing... Quote Link to comment
