Script to change a Record value?
Hello all,
Can anyone please point me in the direction of a command to set the record value of a PIO?
Specifically, in Spotlight: each Light (Device) has a checkbox for the "Draw Beam" option in the object info palette. Unfortunately, this check box is waaaay down in a long list of fields/records. So it it time consuming to toggle its state.
If I could write a script to change the "Draw Beam" record value to false or true, then I could make a tool which could be accessed via a simple right-click or other shortcut.
I am using VW12.5.0 on a MacIntel Powerbook.
Thanks,
Matt Zelkowitz
Available Light
Matt,
What you are trying to do can be achieved without any programming. By changing the order of the pio parameters, you can set the parameter at the top so that it may be viewed on the object info palette.
Otherwise, if you still want to script it, the following will toggle the value of selected pio's.
PROCEDURE TogglePar;
PROCEDURE ProcessObj(ObjHdl: HANDLE);
VAR
curState: STRING;
BEGIN
curState:= GetRField(ObjHdl,'Pio name','Draw Beam');
UprString(curState);
IF curState = 'TRUE' THEN
SetRField(ObjHdl,'Pio name','Draw Beam','False')
ELSE
SetRField(ObjHdl,'Pio name','Draw Beam','True');
END;
BEGIN
ForEachObject(ProcessObj,((SEL=TRUE)));
END;
Run(TogglePar);
The only thing you need to do is substitute 'Pio name' for the actual name of your pio.
  • 2 weeks later...
