sok412 Posted January 19, 2007 Share Posted January 19, 2007 When I print drawings there is a poched wall floating on the page- it is not on the screen and occurs in different drawings, different locations and happens when printing to the plotter and the printer. I tried updating to 12.5.1 (which sounds like it may have been a mistake) but that has not solved the problem either. Any ideas? Quote Link to comment
Guest Posted January 19, 2007 Share Posted January 19, 2007 Are you using a Mac or PC? Quote Link to comment
Guest Posted January 19, 2007 Share Posted January 19, 2007 (edited) what os version, what printer? what happens when you export a PDF file? What happens when you open the file in preview before printing it? Edited January 19, 2007 by Katie Quote Link to comment
sok412 Posted January 22, 2007 Author Share Posted January 22, 2007 I'm using OS 10.4.6 and printing to a HP488CA and a Epson 1280- it happens in both. When I preview or print to .pdf it happens as well. Quote Link to comment
sok412 Posted January 22, 2007 Author Share Posted January 22, 2007 if I export back to V10.5 I can print fine from there. Quote Link to comment
Guest Posted January 22, 2007 Share Posted January 22, 2007 Send the file along with a description of the problem to tech@nemetschek.net Quote Link to comment
Donald Wardlaw Posted January 22, 2007 Share Posted January 22, 2007 A few years back I had a problem like that. Not walls actually, but lines running across the drawing that should not be there. I think one work around was to export the file to vectorscript then reimport. Regards, Donald Quote Link to comment
sok412 Posted January 22, 2007 Author Share Posted January 22, 2007 Thanks. Actually I had a problem like this with 10 as well. Then it was huge arcs that appeared across the drawing when printed- but not always like this. That could usually be solved by taking arcs in the drawing and converting to lines a few at a time until the lines went away. Quote Link to comment
