ruler and object don't match
lulu
Thanks for all the help. I have tried the suggestions you and Katie have given and they haven't solved the problem of the ruler not aligning with my drawing. If I move the objects up one, then I have to move every object I insert into the drawing, since they all insert at -1 according to the ruler (0 according to object info). I have checked and the layer z is O, though that wouldn't matter as long as the objects are within that layer. The wall style settings are at 0. The problem occurs with all the objects I've tried, not just walls.
