Tom K
Export PDF (Batch)
Has anyone else run into this. I have a VW file with fifteen SheetLayers, On the sheets I have notes, viewports of floorplans, and JPG images.
When I use the PDF Batch Export command I get a very nice multipage PDF document, except that none of my JPG images show up.
When I use the Batch Print command then select "save as PDF" I get fifteen separate PDF files, but my JPG images show up fine.
Also the things like fills do not look the same when generated by the two different methods. The batch print command creates a much better quality PDF image.
VW 12.5, Imac G5, Mac OS X 10.4.8
I have run into the same issue.
Here is a workaround I used.
I converted the originals to pdf files and then imported the pdf files into the Vectorworks document. The images then printed properly.
I don't know why the imported jpg images would not print.
