I know that there is a special key combination to select and use a tool and then snap back to the previous tool used. However, back in version 8, all you had to do to toggle between any two tools was to repeatedly hit the key for any given tool. For example, you have the "A" key set to select the Arc tool; you have the "P" key set to select the Polyline tool; you've already pressed the "P" key and drawn a polylinee; next you want to select the Arc tool so you press the "A" key and draw away; to re-select the Polyline tool you could press the "A" key again and it would toggle back to the peviously selected tool (in this example the Polyline tool). PLEASE bring this back!!!!!!!!!!!!!!!!!! Don't replace the current method, just add this one back in.
Brian J Poole
2 answers to this question
