kingfisher9704 Posted November 10, 2006 Share Posted November 10, 2006 Hello, i'm running vw 11, and i'm running into a curious problem Every time i insert an instrument onto my plot, there is a slight delay. then the label is applied to the light, then after about 2 seconds, VWs closes. i'ver tried restarting my computer, but to no avail, i cannot seem to keep VW open after i insert a instrument. I haven't tried inserting any other symbol, but have a feeling it's related to teh label manager or something. Anyway, not sure if i've conveyed this info well enough, but if anyone has had this problem before or could give me info, i would very thankful Quote Link to comment
kingfisher9704 Posted November 11, 2006 Author Share Posted November 11, 2006 Okay, i lied, Vector works randomly exits after about two mintutes regardless of what i'm doing (or so i think) counld his have anything to do with the software or is this an issue with my computer? Quote Link to comment
kingfisher9704 Posted November 11, 2006 Author Share Posted November 11, 2006 okay, i lied again. i've been experimenting, and vector works only close when i change my layer to what i have as Fixtures, or try to edit or add a fixture anywhere on the plot Quote Link to comment
Jim_Allen Posted November 12, 2006 Share Posted November 12, 2006 You could go back far into the spotlight posts and see if there was a thread about your problem. You should get 11.5 at least if you can still download it from VW. Not sure anyone is still on V11. Highly recommend V12.5, if you can afford it, V12 solved many problems. Quote Link to comment
