ErichR Posted August 28, 2006 Share Posted August 28, 2006 Upon using a Lintel window Part that is wider than the window opening, the elevation view of the window shows the wall to be cut at an angle from the lintel to the sill. This is really yucky-looking and makes the lintel part unusable, unless there is a setting that allows the wall to close in around such lateral projections that are wider than the overall window width. Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted August 28, 2006 Vectorworks, Inc Employee Share Posted August 28, 2006 Look for this to be fixed in an upcoming maintenance release of VW. Quote Link to comment
ErichR Posted August 28, 2006 Author Share Posted August 28, 2006 Robert, thanks. Quote Link to comment
ErichR Posted October 11, 2006 Author Share Posted October 11, 2006 In 12.5.0: Create a symbol with two windows with six inches or so between them. Make a 3D louver 42"x16" and center this between and below the two windows. Make a new symbol of this combination. Insert the new symbol in a wall. Look at a rendered elevation of the wall. It will have diagonal lines between the bottom of the louver and the lower, ourside corners of the windows. Within the triangles created there will be a void in the wall. Quote Link to comment
