OhGeorgie Posted August 14, 2006 Share Posted August 14, 2006 I'm new to vectorscript and trying to make a set of plug-ins for the UK beam library. There are metric and imperial North American beams included with VW12 but not for the UK sizes. I've started with the following script: BEGIN result:= GetCustomObjectInfo(objname, oh,rh,wh); IF result THEN BEGIN Otype := PTYPE; IF Otype = '100 X 50' THEN PFCtype := 1 ELSE PFCtype := 2; CASE PFCtype OF 1: BEGIN H := 100; W := 50; Tf :=7; Tw := 5; END; 2: BEGIN H := 180; W := 75; Tf :=10; Tw := 5; END; END; PushAttrs; FillPat(2); Poly(0,0, W,0, W,Tf, Tw,Tf, Tw, H-Tf, W,H-Tf, W,H, 0,H, 0,0); PopAttrs; END; END; Run(Box1); But I have a few questions. 1. How do I introduce a fillet to the channel. I couldn't find a function for Fillet in vectorscript and also wouldn't know how to reference the appropriate corners that are to be filleted. 2. Can I set up an array of values for the different channel sizes. ie: 100x50: 100 150 7 5 180x75: 180 75 10 5 etc. so that I could set up my 'CASE' portion of the code to just search the array of values. Thanks for any help. Also are there any sites with examples of various scripts that I can go to? Andreas Quote Link to comment
MullinRJ Posted August 14, 2006 Share Posted August 14, 2006 Your Polygon can also be written as: ClosePoly; { if you want it closed, recommded } BeginPoly; MoveTo(0, 0); LineTo(W, 0); LineTo(W, Tf); LineTo(Tw, Tf); LineTo(Tw, H-Tf); LineTo(W, H-Tf); LineTo(W, H); LineTo(0, H); LineTo(0, 0); { optional } EndPoly; If you want to fillet the two inside corners: ClosePoly; BeginPoly; MoveTo(0, 0); LineTo(W, 0); LineTo(W, Tf); ArcTo(Tw, Tf, 5); ArcTo(Tw, H-Tf, 5); LineTo(W, H-Tf); LineTo(W, H); LineTo(0, H); LineTo(0, 0); { optional } EndPoly; For examples in coding, goto VectorDepot (www.VectorDepot.com) HTH, Raymond Quote Link to comment
OhGeorgie Posted August 15, 2006 Author Share Posted August 15, 2006 Raymond, thank you so much. That is a much nicer way of doing a polyline! Does the ArcTo(x,y,r) fill in the straight line between the two corners? It makes an arc that ends at (x,y) and then a straight line from the tangent to the previous point. I didn't get that at all from the help file! Thanks again, Andreas Quote Link to comment
MullinRJ Posted August 15, 2006 Share Posted August 15, 2006 (edited) Hi Andreas, Always happy to help. Yes, ArcTo does continue the straight line segment from the last point. One thing to note, ClosePoly and its converse OpenPoly stay in effect until changed, so you don't need one for each BeginPoly. Also, it is a good practice for most Polylines to start and end with Corner Points - MoveTo and LineTo. For Open Polylines, it's always necessary. Raymond Edited August 15, 2006 by MullinRJ Quote Link to comment
