Heroine Posted May 15, 2006 Share Posted May 15, 2006 I know I probably did something stupid...but I have been trying to trace my steps or just figure it out for 3 days. I set my views and the wireframe perspective is fine, except when I render it, it loads, and then the image goes blank!!!!! If anyone has a clue why this happens, I will love you forever. lol, I even made sure it wasn't my floor floating 10 feet up (cause thats happened too). I hope someone actually sees this post sometime tonight. ARGH...frustration...and finals. not a good combo. Quote Link to comment
Heroine Posted May 15, 2006 Author Share Posted May 15, 2006 Oh, and the rendering doesn't even load up all the way before it snaps to nothingness. I was using it earlier for another project and it was rendering fine. Whether its a preference I messed with, I'm not sure, but it's definitely the file itself. The 'Render Bitmap' tool lets me see it, but I don't even know what that tool means. I haven't been using VW for too long, but I'm not a complete retard. HELP....help. Quote Link to comment
Kaare Baekgaard Posted May 16, 2006 Share Posted May 16, 2006 Apart from the obvious - that there is some large shape blocking the view (I once did this with an interior, where I had accidentally reversed the Z- and Delta Z values of a floor, so it filled up the entire interior) - try copy/paste-in-place different elements into a blank document and render them for testing. I once had an experience similar to yours in an earlier version of VW. The culprit turned out to be a solid object, that for some reason spoiled the applications ability to render the scene. Quote Link to comment
Heroine Posted May 22, 2006 Author Share Posted May 22, 2006 thanks. I transferred the entire drawing to a new document and it worked. I never found the object, but it was definitely the document. Quote Link to comment
