scottparker Posted April 22, 2006 Share Posted April 22, 2006 Greetings all, I'm having trouble moving some of the labels on several of my units. Some work just fine while others don't. When a unit is highlighted, I can grab each label's little square and try to drag it to a new location, but nothing happens. I have tried different methods of testing out the problem with no luck. Symptoms: Some lights: all labels move fine. Some lights: no labels move. Side by side comparison of two identical lights, one works and the next doesn't. The only difference that I can figure is various lights are from various incarnations of this reduxed rep plot. Any ideas? Thanks and take care, Scott Quote Link to comment
Ben624 Posted May 17, 2006 Share Posted May 17, 2006 I have had the same problem. I can't see any reason why one should work and another shouldn't, but sure enough... Can anyone help? Quote Link to comment
Nik Posted May 25, 2006 Share Posted May 25, 2006 If you're trying to move channel circles or other containers unfortunately you can't unless they have a value. I think this is something that should be fixed. Either don't show the container or allow it to be moved. Quote Link to comment
