BillW Posted December 19, 2005 Share Posted December 19, 2005 I have a large environment built with Vectorscript which works perfectly in VW11-11.5 I have ported to VW12 PC with the system broken in one major respect. I automatically create sheet layers with elevations/plans as viewports of a 3D model, each viewport contains annotations and some are cropped. Running in VW12 PC my sheet/viewport creation scripts hang in VW12 Is there anything I should be aware of with changes to VW12? I would appreciate some help from NNA The logic of the script is make model layer active set model view ie FRONT draw crop rectangle on model layer draw dimension/notes objects on model layer and store handles to objects create viewport on sheet layer set viewport crop object >>>>>>>>>>hangs system on this call attach dimension/notes objects to viewport using handles to objects stored previously set viewport details set viewport layers set viewport classes move viewport to correct position on sheet layer I also update the viewport. I have also tried changing the order of the calls ie putting annotation last but with no success The offending function is function AddVPAnnotationObject(vportH,objH); If I strip out all annotation calls the sheet/viewports are built correctly. The code snippet is below >>>>>>>>>>>> hangs VW12 procedure setvpannotate(vportH : HANDLE; objlist : array[1..200] of HANDLE; objcnt : INTEGER); Var i : INTEGER; btest : BOOLEAN; begin for i := 1 to objcnt do btest := AddVPAnnotationObject(vportH,objlist); end; >>>>>>>>>>>>>>>>>>>>>>main call lscal := getlscale(designlyrH); cx2 := 0; {elevations at origin} cy2 := (shedabove-((shedabove+shedbelow)/2))/lscal/2; layer(kSHEDLYR); setviewtype(viewtype); rect(-shedlength/2,shedabove+kCROPBORDER,shedlength/2,-(shedbelow+kCROPBORDER)); cropobjH:= Lnewobj; setls(cropobjH,0); objcnt := 0; case dimtype of kDIMELEVFRONT : dimelevfront(viewtype,lscal,shedabove,shedbelow,FALSE,showdims); kDIMELEVBACK : dimelevfront(viewtype,lscal,shedabove,shedbelow,TRUE,showdims); kDIMELEVLEFT : dimelevleft(viewtype,lscal,shedabove,shedbelow,TRUE,showdims); kDIMELEVRIGHT : dimelevleft(viewtype,lscal,shedabove,shedbelow,FALSE,showdims); end; vpH := createVP(sheetlyrH); croptest := setvpcropobject(vpH,cropobjH); >>>>>Hangs system setvpannotate(vpH,annotlist,objcnt); setvpdetails(vpH,0,kVPWIREFRAME,viewtype,vwscale,1,TRUE,TRUE); {kVPHIDDENLINE kVPWIREFRAME} layernames[1] := kSHEDLYR; setvplayervis(vpH,layernames,1,kNOCHECK,kVISIBLE,FALSE); setelevclass(dimtype); setclass(vpH,kVWPGENCLASS); layer(getlname(sheetlyrH)); hmove(vpH,cx1-cx2,cy1-cy2); Quote Link to comment
BillW Posted January 4, 2006 Author Share Posted January 4, 2006 Not much response yet from NNA!!! I have reason to beleive that Viewport annotation is broken at VW 12 I drew a rectangle, added two dimensions and a text block on the design layer and created a viewport. I did an Export Vectorscript (which currently doesnt handle viewport annotation). I edited the Vectorscript file to add viewport annotation. If I do an Import>Vectorscript then Vectorworks hangs. Could somebody else please check this out - see code below. I am running VW 12 on PC. If a single object is added as annotation I have seen it work. If I draw a point object on the design layer and check its parent type I get 11 - a group and NOT 31 a layer {----------------------------------------------} Procedure LoadFile; VAR hatchName, gradientName, objectName:STRING; result, index, segmentIndex:INTEGER; boolResult:BOOLEAN; top, left, bottom, right:REAL; tempHandle, tempHandle1, tempHandle2, gradientHandle, objectHandle, layerHandle, viewportHandle:HANDLE; obj1,obj2,obj3 : HANDLE; {---- added to standard Vectorscript export} BEGIN {VectorWorks Version 12.0.0 (49891)} {Global Characteristics} DrwSize(1,1); SetUnits(0,1,0,25.400000000000006,'mm',' sq mm'); PrimaryUnits(0,1,1,2,6,FALSE,FALSE); SecondaryUnits(7,1,2,FALSE,FALSE); SetPrefLongInt(162,1); SetPrefLongInt(169,1); SetPrefLongInt(171,3); SetPrefLongInt(172,3); SetPrefLongInt(212,1); SetPrefLongInt(219,1); SetPrefLongInt(221,3); SetPrefLongInt(222,3); SetPrefInt(174,0); SetPrefInt(224,0); SetPref(167,FALSE); SetPref(173,TRUE); SetPref(223,TRUE); SetPref(175,FALSE); SetPref(225,FALSE); GridLines(9.999999999346619); PenGrid(1.999999999346617); SetPrefReal(73,0); SetOriginAbsolute(0,0); SetPref(37,TRUE); SetPref(38,TRUE); SetPref(5,FALSE); OpenPoly; SetDashStyle(TRUE,2,0.041656,0.041672); SetDashStyle(TRUE,2,0.097214,0.041671); SetDashStyle(TRUE,2,0.208328,0.041672); SetDashStyle(TRUE,2,0.263885,0.041657); SetDashStyle(TRUE,2,0.013885,0.027771); SetDashStyle(TRUE,4,0.125,0.041656,0.013886,0.027786); SetDashStyle(TRUE,6,0.125,0.041656,0.125,0.041672,0.013886,0.027786); SetDashStyle(TRUE,6,0.125,0.041656,0.013886,0.027786,0.013886,0.027786); SetDashStyle(TRUE,4,0.75,0.055557,0.138886,0.055557); SetDashStyle(TRUE,6,0.75,0.055557,0.138886,0.055557,0.125,0.0625); SetPrefInt(121,0); SetPrefReal(68,0); SetPrefReal(69,0); SetPrefReal(70,1); {End of Global Characteristics} {Record Format Entries} {Begin Visible Record Format Entries} {End of Visible Record Format Entries} {Begin Hidden Record Format Entries} NewField('NNACartoon','Family','7',1,0); SetObjectVariableBoolean(GetObject('NNACartoon'),900,FALSE); NewField('NNACartoon','Prototype','1',1,0); SetObjectVariableBoolean(GetObject('NNACartoon'),900,FALSE); NewField('NNACartoon','Version','1',1,0); SetObjectVariableBoolean(GetObject('NNACartoon'),900,FALSE); NewField('NNACartoon','Line Color','0',1,0); SetObjectVariableBoolean(GetObject('NNACartoon'),900,FALSE); NewField('NNACartoon','Line Color G','0',1,0); SetObjectVariableBoolean(GetObject('NNACartoon'),900,FALSE); NewField('NNACartoon','Line Color B','0',1,0); SetObjectVariableBoolean(GetObject('NNACartoon'),900,FALSE); NewField('NNACartoon','Line Width','1',3,0); SetObjectVariableBoolean(GetObject('NNACartoon'),900,FALSE); {End of Hidden Record Format Entries} {End of Record Format Entries} {Worksheet Entries} {End of Worksheet Entries} {Gradient Definition Entries} {End of GradientDefinition Entries} {Hatch Definition Entries} {End of Hatch Definition Entries} {Symbol Library Entries} {End of Symbol Library Entries} {Layer Characteristics} layerHandle := CreateLayer('Design Layer-1', 1); SetScale(100.00000000000003); ShowLayer; CopyMode(8); LFillFore(0,0,0); LFillBack(65535,65535,65535); LPenFore(0,0,0); LPenBack(65535,65535,65535); Projection(6,0,11899.391999999614,-5949.6959999991541,5949.6959999991541,5949.6959999991541,-5949.6959999991541); {End of Layer Characteristics} {Object Creation Code} NameClass('None'); PenSize(2); PenPat(2); FillPat(1); PenFore(0,0,0); PenBack(65535,65535,65535); FillFore(0,0,0); FillBack(65535,65535,65535); Rect(-999.99999999934687,999.99999999934687,999.99999999934687,-999.99999999934687); TextFont(GetFontID('Arial')); TextSize(9); TextFace([]); TextFlip(0); TextRotate(0); TextSpace(2); TextJust(1); TextVerticalAlign(1); TextOrigin(-4649.9999999993479,3099.9999999993474); BeginText; 'text' EndText; obj1 := Lnewobj; {---- added to standard Vectorscript export} NameClass('Dimension'); SetDimStd(5); LinearDim(-999.99999999934687,999.99999999934687,999.99999999934687,999.99999999934687,1749.999999999347,0,1795,771,0); SetPrimaryDim(LNewObj,TRUE,FALSE,'','',1); SetSecondaryDim(LNewObj,TRUE,FALSE,'[',']',1); obj2 := Lnewobj; {---- added to standard Vectorscript export} LinearDim(999.99999999934687,999.99999999934687,999.99999999934687,-999.99999999934687,1599.999999999347,1,1795,771,0); SetPrimaryDim(LNewObj,TRUE,FALSE,'','',1); SetSecondaryDim(LNewObj,TRUE,FALSE,'[',']',1); obj3 := Lnewobj; {---- added to standard Vectorscript export} SetZVals(0,0); {Layer Characteristics} layerHandle := CreateLayer('Sheet Layer-1', 2); boolResult := SetSheetLayerUserOrigin(layerHandle,0,0); {End of Layer Characteristics} {Object Creation Code} NameClass('None'); NameObject('Viewport-1'); {Begin Viewport: 'Viewport-1'} {Creation} objectHandle := GetObject('Sheet Layer-1'); viewportHandle := CreateVP(objectHandle); {Viewport Layer Visibilities} layerHandle := GetObject('Design Layer-1'); boolResult := SetVPLayerVisibility (viewportHandle, layerHandle, 0); {Viewport Class Visibilities} boolResult := SetVPClassVisibility (viewportHandle, 'None', 0); boolResult := SetVPClassVisibility (viewportHandle, 'Dimension', 0); {Viewport Data} SetObjectVariableReal (viewportHandle,1003,20); SetObjectVariableInt (viewportHandle,1000,6); SetObjectVariableInt (viewportHandle,1001,0); SetObjectVariableReal (viewportHandle,1002,23.425); SetObjectVariableBoolean (viewportHandle,1005,TRUE); SetObjectVariableLongInt (viewportHandle,1006,0); boolResult := SetViewMatrix (viewportHandle,0,0,0,0,0,0); {Viewport Annotation ---- added to standard Vectorscript export} message(concat('Object types = ',gettype(obj1),' ',gettype(obj2),' ',gettype(obj3),' ----starting add annotatoin')); boolResult := AddVPAnnotationObject(viewportHandle,obj1); boolResult := AddVPAnnotationObject(viewportHandle,obj2); boolResult := AddVPAnnotationObject(viewportHandle,obj3); message('After add annotation'); ResetObject (viewportHandle); GetBBox (viewportHandle, left, top, right, bottom); HMove (viewportHandle,-90 - left,100 - top); {End Viewport: 'Viewport-1'} SetZVals(0,0); {End of Creation Code} {Classes} NameClass('None'); SetClFillFore('None',0,0,0); SetClFillBack('None',65535,65535,65535); SetClPenFore('None',0,0,0); SetClPenBack('None',65535,65535,65535); SetClFPat('None',1); SetClLS('None',2); SetClLW('None',2); SetClUseGraphic('None',FALSE); NameClass('Dimension'); SetClFillFore('Dimension',0,0,0); SetClFillBack('Dimension',65535,65535,65535); SetClPenFore('Dimension',0,0,0); SetClPenBack('Dimension',65535,65535,65535); SetClFPat('Dimension',1); SetClLS('Dimension',2); SetClLW('Dimension',2); SetClUseGraphic('Dimension',FALSE); {End of Class Entries} {Default Attributes} PenSize(2); PenPat(2); FillPat(1); Marker(0,0.125,15); PenFore(0,0,0); PenBack(65535,65535,65535); FillFore(0,0,0); FillBack(65535,65535,65535); {End of Default Attributes} END; Run(LoadFile); Quote Link to comment
BillW Posted January 13, 2006 Author Share Posted January 13, 2006 Still trying to sort out annotation problem. I got a response I didnt expect. anobjH := GetVPGroup(vportH,2); {2 = Annotation} alrtdialog(concat(gettype(vportH),' ',gettype(anobjH),' ',anobjH)); This returns 122 0 0 Which signifies I have a handle to a Viewport but no handle to the annotation layer. I wonder what is happening? Is there a cetain point when Viewport layers are created? Quote Link to comment
